79JON
Ok.. I figured this out after I bought everything and now I'm kinda stuck with the parts I have. But anyways, ive got a 71 Duster slant 6 car. I bought a 73 Duster parts car to grab all the 4.5 bolt pattern stuff and disc brake setup. Well.. the K Frame on the parts car was hacked up so it was no good. I thought the K-Frames were the same between the two and didnt think much of it. Also I have already bought slant 6 to 360 schumacher motor mounts that I cant return so Im definetly using those. Today I found out that the Sway bar goes through the K frame on the 73 and up and and on my K frame they go in front. So I was wondering if there was anyway possible that I could make the 73 sway bar work still by using the original slant 6 K Frame?? Has anyone ever had the same situation and made it work? I might just be without a Sway bar I guess.
