340 Dart
I don't know ****.
Sean came over last night (he is a member here) and we took the power brakes off of the 75 and installed the aluminum master cylinder. We probably dropped 30lbs off the nose of this thing and the brakes work better than before!
Sean made the adaptor plate (thank you) and it is a pretty easy swap if you don't cut the pushrod too short and have to weld it back together (my brilliance at work here, LOL). Thanks for giving up your Sunday evening to help me out Sean!
It took longer that expected (see brilliance above), but I have kick *** brakes, dropped 30 lbs off my car, and I got to use my new welder....................
