64physhy
As many of you know, I flattened the cam and destroyed 3 lifters on my stroker a while back. I finally tore it down today, and this is what I found (no pics, I don't think you'd be able to see anything on them).
1.) 2 of the cam bearings are really bad, and 2 others have minor scoring.
2.) 2 of the main bearings have some scoring. Part of the bearing material transferred to the crank main on one of them.
3.) only 1 of the rod bearings showed any wear, it had a score right through the center, but no damage to the crank.
4.) Don't know if this is normal or not, but the piston skirts are rubbing the cylinder walls.
5.) sealant-probably from the oil pan gasket- was clogging a few holes in the oil pick-up tube.
So could this whole thing be caused from lack of oil because of the partially clogged oil pick-up?
I'm definitely going to replace all the bearings and thoroughly clean everything.
What else do I need to do?
