Temp sender not working?
Righty
Bristol UK
The temperature gauge in my 69 Barracuda doesn’t work, as the Queen once said recollections vary about whether it ever did. (I’ve had the car about 7 months).
I ordered a replacement from Rockauto, I popped out the old one and grounded the lead to the block to check that the gauge was responding which it did - needle swung up pretty fast and slowly returned to rest. So I went ahead and fitted the new sender, the coolant was up to the top of the hole so I’m sure it’s sat in the coolant, but still no joy at the gauge.
So not sure what’s happening here, the lead to the gauge and the gauge and voltage regulator would appear good based on testing it to ground? I guess I could just be unlucky and have a bad sender out of the box, but the one that came out looked pretty new too so I’m wondering if there is another issue?
Oh boy, last bad sender thread went on for days, maybe still going. Good parts from aftermarket is a crap shoot. You may have a bad sender. You didn't mention hot water. Gauge won't respond to cold water.
I’ll have to find that thread, I like a good read! I ran the car stationary for a few minutes to see if the gauge moved, I couldn’t see any change at all needle just sat against the stop, I’ll leave it tonight, give the neighbours a rest and let it run for a good while tomorrow to see.
Funnily it’s not hot or cold water, it’s stupidly expensive Evans waterless coolant, I just pissed about £20 on the floor when I unscrewed the sensor and the pressure gave me a little fountain.
Can owners be damaging senders with their hand tools? I'm sure it possible. Anyone know the torque spec for senders? LOL. with the sender installed, sender body to battery neg' should be 0 ohms. Sender terminal to ground should show some varying resistance between 80 and 30 ohms as the water warms.
Definitely a possibility, although I’d say that fear of over tightening anything into an aluminium intake manifold is a very effective torque limiting device! I’ll do the resistance checks tomorrow, my battery is in the boot so would sender body to ground work?
Yes, I would check all grounds (engine to frame, frame to body and body back to engine) and make sure the sender has good contact on the threads. Sounds silly but the dang liquid teflon they throw on the threads or teflon tape can keep a good circuit from working.
I’ve had this happen to me years ago and it stumped me. “Why was the rest of the engine stuff working?”The previous owner had plastic washers on the intake bolts. I was moving to fast to see the electric choke was inop also.
I think i will try to eliminate contamination, perhaps when i was fitting it I got some of the waterless coolant on the thread. I might actually remove the threaded end from the wire, try as I might to pre-twist it before screwing it on the sender it still ends up twisting the wire to get it tight. I’ll replace it temporarily with an eye fitting and give everything a good clean, it will make it easier to test if nothing else.
You can also test the sender with a test light. Sender to battery ground, tip of test light to top of Sender and test light clamp to positive. When Cold, the light will barely glow, hot, bright light. I haven't had much luck with new senders. Buy an old used one if you can find one.
All of the chassis should be ground back to the battery. If everything else works the chassis is ground. The sender should get a 90° booted push on female terminal. Chrysler used a #10 stud so a replacement terminal is very difficult to source. A ring terminal with toothed washer and nut can work but DO NOT OVERTIGHTEN. A dang alligator clamp would be better than damaging senders. The wire needs only to make contact and not fall off. The stamped tin nuts connecting the gauge contact a single thread and they work. :)
Rookie error, but I still don’t own a test light, or crocodile clip jumpers, I shall rectify that tomorrow and check the sender.
Lordie, man, use an ohmeter. Also many? most? test "lights" are now LEDs which dramatically change the test results, depending on what you are doing. I use both and you must understand what effect a lamp drawing "more" current against an led drawing "less" current has on whatever you are doing./ testing
The resistance values have been posted time and again. Warm up the engine to somewhere near running / normal temp, and measure the sender value to the BLOCK. Also check resistance, which should be zero, from the sender case/ hex to the block You can ruin a sender by overtightening, as the wrench can distort the "guts" internally.
L = 73.7 Ohms (empty)
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full
OK so this is a bit left field but here goes.
Is the sender unit a resistor whose impedance is changed by temperature? If so is it correct to assume that the circuit runs from gauge to coolant to block to ground? In other words the conductivity of the coolant grounds the sender? I only ask because Evans waterless coolant is propylene glycol which is non conductive?
I know it’s a bit of a stretch but I’m almost positive that the gauge worked until I changed over to waterless.
M = 23.0 Ohms (1/2)
H = 10.2 Ohms (full
I’ll check the resistance with my multimeter, more dumb questions, but the values above are they from the stud to ground?
Well sir, I have an old Snap On test light. I am in Kindergarten compared to you having a college degree with a master's when it comes to electrical. I'm sorry, when electrical directions get into ohms and on and on, you lose me. All that I know is what I said works for me, and it's KISS, keep it simple. The OP can stay with you on this one. I'm out.
Well I still need to buy a test light and jumpers:) Problem is all you guys over there have old Snap On test lights, analogue dwell tach testers, solid metal cased timing lights stacked up on your shelves. Try finding any good quality gear like that here in old cheapskate UK, everything’s of Temu.
My younger brother will beg me and all of you,, "throw away those pizzy test lamps. Learn to use a meter. If I had a nickel for every wheel speed sensor killed by idiots with those damn things". Yeah he does Field Failure Analysis for Robert Bosch. Something about those sensors changed a few years ago. OK, I'll use it where I feel safe to but I'll do the research b4 I screw our daily driver with it.
Did you buy the Standard Motor Products TS17 Temp Sender/Sensor? That should work.
Yes that’s the one. At this stage I’m assuming user error! I’ll test it and the old one tomorrow as best I can.
The electrical conductivity of the coolant is not involved with the type of sending unit with which you are dealing. The thermal conductivity of the coolant, and its surface tension, can affect response time of the sending unit to a negligible degree. The coolant itself is not part of the circuit path, which flows as shown in the following:
Battery Positive (+) --> Voltage Limiter --> Gauge --> Sending Unit --> Engine Manifold/block --> Battery Negative (-)
The temperature sending unit in question is a negative temperature coefficient resistor. The impedance of the unit is essentially and wholly a direct current function of resistance only.
Replacement components can be bad, and modern units have a much worse record than older aftermarket and original units. For testing the sending unit in operation, the following cardinal points and resistance values are of interest:
  • Ambient temperature at about 25 degrees Celsius, before running engine, gauge needle at lowest point, sending unit resistance = 360 Ω
  • Engine at ~49 degrees Celsius - Needle moves to Cold mark on the temperature gauge, sending unit resistance = 72 Ω
  • Engine at ~88 degrees Celsius - Needle moves to middle on the temperature gauge, sending unit resistance = 22 Ω (approximate range of ~18 to ~26 Ω)
  • Engine at ~110 degrees Celsius - Needle moves to Hot mark on the temperature gauge, sending unit resistance = 9 Ω
Note that some gauges have intermediate marks above Cold and before Hot and others have actual numeric markings from 120 to 170 to 230 to 250 degrees Fahrenheit.
Also note that Chrysler revised the actual numeric equivalence to the hot and cold marks a couple of times, but the resistance values of the sending units and their correspondence to the positions on the gauges themselves are essentially the same with a slight variance for peak temperature. This correspondence is true for the temperature sending units as well as those for fuel level and oil pressure which operate with most of the King-Seeley Constant Voltage type gauges Chrysler used from about 1960 through 1989 on domestic rear wheel drive vehicles.
When checking the resistance of the temperature sending unit, probe the unit terminal post and body to check the unit itself. Probe the terminal post to manifold to check body to ground, and further check terminal post to the battery negative (-) terminal for a more end to end post to ground test. These tests should show the same effective resistance. Direct continuity between the body and the points can also be tested directly by probing between the unit body and the ground points. The resistance should be effectively zero.
You tested the wiring to gauge set up by shorting the terminal lead to ground and watching the gauge response. This confirms the circuit is operational, and although not a fully thorough check, usually sufficient. Other functional checks can be made by using a voltmeter between the sending unit post (connected) and ground or a test light between the sending unit post and wiring terminal. With the key on, watch for cycling voltage on the voltmeter (an analog meter is better in this case), or for the flashing of the test light as the voltage limiter cycles. As mentioned, a quick check of the sending unit as it warms can be performed with the test light leads between the unit post and +12 volts at the battery or other point and watch for the intensity to increase as the resistance decreases as the engine warms.
A quick test lamp can be made from an 1156 bulb, a couple of wires, and a couple of clips. For testing between the sending unit and sender wire, a 6 volt bulb, such as 1129, better matches for the voltage limiter output. Test lights, are quick and simple tools, but are more qualitative than quantitative. You have a meter which can do the quantitative checks as well.
Although it sounds like your gauge and associated wiring is okay, if desired to check cardinal points of the gauges, use the following resistance values:
Chrysler Specification:
  • Cold = 72 Ω
  • Middle = 22 Ω
  • Hot = 9 Ω
Gauge position tolerance at these points is listed in the service manual.
Miller Special Tool Specification (used by Chrysler for testing):
  • Cold = 75 Ω +/-5% -> 71.2 - 75.8 Ω
  • Middle = 22 Ω +/-5% -> 20.9 - 23.1 Ω
  • Hot = 10 Ω +/-5% -> 9.5 - 10.5 Ω
The Miller C-3826 tester can be used to test these points, or the point resistances can be made using fixed resistors or a combination thereof, variable resistors, decade resistance boxes.
Just making sure I understand
You shorted the sender lead to the block and the temp gauge moved to HOT fast. You removed the grounded sender lead from ground and the gauge slowly went back to cold. Is that correct.
If you kept the sender lead grounded for any amount of time you MAY have burnt out your gauge.
What is the sender part number you bought?
If you ground the sender lead again does the gauge move like before?
The factory lead going to the sender are push on and at times loose and need to be squeezed a little to tighten up to make connection. I did not read this whole thread. This is just something I thought I would mention because it already happened to me. The connection was to large to make contact on the new thinner sender. Just something you could check.
Agree with post #8.
I just use a red side marker light that grounds out on the temp sending unit pin on my engine run stand. Same you can test your sending unit this way.
Starts up cold and the red light is dim. When up to temp it is normal brightness. If the engine starts to get hot, the red light gets very bright.
Makes a simple temp gauge just to check things out.
