TF 727 Guru?
Discussion in 'Transmission and Drivetrain Tech' started by Ghostrider 67, Jan 7, 2019.
  1. Ghostrider 67
    Ghostrider 67 Well-Known Member
    95
    45
    Oct 25, 2015
    The Sticks, Vermont.
    Local Time:
    9:45 PM
    Never mind.
  2. j par
    j par Well-hung Member
    10,562
    3742
    Jul 2, 2014
    Portland Oregon
    View My Photos
    Local Time:
    6:45 PM
    Okay I know those cats are messing with you but here's the slow scoop on that. they're trying to say is the shaft that you want you know doesn't go all the way through the transmission it stopped short at the front and then butts into the one that actually does come out the front. I believe what they were good in that is theirs Factory clarence's between the two that have to be pretty correct. So getting them together gets allI the tolerance is correct automatically more or less without fighting it.
    All 727 are strong Transmissions LOL if you want my personal opinion if that transmission ran so good I would try and sell it and just get the correct one it's just so much less hassle. Even to get the correct one and put $120 rebuild kit in it.
  3. Ghostrider 67
    95
    45
    Oct 25, 2015
    Local Time:
    9:45 PM
    Okay, thank you. That clears up a bunch. It IS a good unit and I really would like to keep it. Sigh...I guess I will have to sell it, although I am fairly sure there has been some significant upgrades put in it that I will lose with a new unit. Also, I don't have the money to just go and buy a whole new unit. Thanks for the advice and I will think about what I can do here.
  4. d55dave
    d55dave Well-Known Member
    2,257
    745
    May 20, 2010
    Kelowna, British Columbia
    Local Time:
    8:45 PM
    It is an easy enough task to change the output housing and shaft, to convert the transmission to a long tailshaft slip yoke style. You just need to ensure that the output shaft you use is correct to mate to the forward planetary carrier. Other than the oddball 65 and prior stuff there are only two shafts, 75 and earlier and 76 and later. The difference is that the splines on the forward end of the shaft are cut differently and must match the planetary carrier.
  5. Ghostrider 67
    95
    45
    Oct 25, 2015
    Local Time:
    9:45 PM
    So if I buy a 75 and earlier unit I will be okay? Yes? Mine is a 1973.
    • Like Like x 1
    • d55dave
      2,257
      745
      May 20, 2010
      Local Time:
      8:45 PM
      Yes, as long as someone hasnt already changed the guts to later style. Your best bet is to pull it apart, once apart you can tell visually what style output shaft you have and need. I have both an early and a late style if you need one.
      • Thanks! Thanks! x 1
      • Agree Agree x 1
      • 383Scampman
        383Scampman Well-Known Member
        1,109
        395
        Nov 24, 2013
        New Hampshire
        Local Time:
        9:45 PM
        Since you live in Vermont , get in touch with Chris or Craig Munroe @ TSR racing in Gilsum/Keene New Hampshire . their father , Carl Munroe , wrote the book on 727's . They built my transmission and it's no joke . These folks are super nice and super easy to do business with . It is a business , however , and they are super busy . Try them , you got nothing to loose .
        • Ghostrider 67
          95
          45
          Oct 25, 2015
          Local Time:
          9:45 PM
          I will get with them and thank you. I am also talking with Torqueflite/ patty on e bay.
        • j par
          10,562
          3742
          Jul 2, 2014
          Portland Oregon
          View My Photos
          Local Time:
          6:45 PM
          I usually see core transmissions for around a hundred bucks on Craigslist pretty often. Oh, like that with $120 rebuild kit and and $80 transgo shift kit and you're off and banging gears.
        • j par
          10,562
          3742
          Jul 2, 2014
          Portland Oregon
          View My Photos
          Local Time:
          6:45 PM
          I mean think about it if you were going to take that shaft out you were going to rebuild the entire transmission anyways.
          • Ghostrider 67
            95
            45
            Oct 25, 2015
            Local Time:
            9:45 PM
            That's true. Sigh, I just hate to toss/sell a tranny I know to be good and start over again. Although, I suppose that I could take the performance parts out of this one and incorporate them into the next one.
            • Like Like x 1
            • j par
              10,562
              3742
              Jul 2, 2014
              Portland Oregon
              View My Photos
              Local Time:
              6:45 PM
              What performance parts are in it again?
            • j par
              10,562
              3742
              Jul 2, 2014
              Portland Oregon
              View My Photos
              Local Time:
              6:45 PM
              I'm at an appointment waiting to get the shot in my eyeball so I won't be talking for long out here as I won't be able to see my phone here in a few minutes. But I'll be back in a few hours LOL
            • j par
              10,562
              3742
              Jul 2, 2014
              Portland Oregon
              View My Photos
              Local Time:
              6:45 PM
              Also I'm no 727 Guru. I rebuild a couple 904 before and they're very similar if not the same in some instances. 70ARRCuda has helped many people with their automatic transmissions and has even sent a few people rebuild DVDs. Very boring and very dry but very informative.
            • j par
              10,562
              3742
              Jul 2, 2014
              Portland Oregon
              View My Photos
              Local Time:
              6:45 PM
            • Ghostrider 67
              95
              45
              Oct 25, 2015
              Local Time:
              9:45 PM
              I have a couple of local sources looking for one for me today. Not sure what all is in that trans,
            • j par
              10,562
              3742
              Jul 2, 2014
              Portland Oregon
              View My Photos
              Local Time:
              6:45 PM
              If you were going to try and change that shaft out you were fixing to learn...
              • Agree Agree x 1
              • j par
                10,562
                3742
                Jul 2, 2014
                Portland Oregon
                View My Photos
                Local Time:
                6:45 PM
                it's basically the pump that pulls off the front then a drum with the reverse and 3rd gear clutches and a drum behind that with the first and second gear clutches and behind that is the planetary gear. taking one apart is just watching a couple videos and doing just that taking it apart one piece by one piece spreading it out changing out the seals and things they give you and cleaning it all and putting it back in the same way you took it out with the new seals in it and gaskets. That's all there is to it. You pull out the clutch dish and the plates and you replace the clutch disc in her plates the same way you took them out of each drum. It's really a no-brainer once you get in there. Just a lot of cleaning.
                • j par
                  10,562
                  3742
                  Jul 2, 2014
                  Portland Oregon
                  View My Photos
                  Local Time:
                  6:45 PM
                  ^^^that was just one long voice command I wasn't going to take the time to correct all that so I hope it didn't say nothing weird like this....
                  • Like Like x 1
                  • Ghostrider 67
                    95
                    45
                    Oct 25, 2015
                    Local Time:
                    9:45 PM
                    No, it didn't sound like a backwards record.." Freddy is the devil...Freddy is the devil"....or anything..lol. I surmised as much, that it was not really a super technical deal or anything. Something other than a straight up rebuild might be another story though. I do have that manual by Munroe over in NH. That will be good too.
                  • fishy68
                    fishy68 Tyr Fryr's Inc. FABO Gold Member
                    16,761
                    710
                    Jan 11, 2005
                    Central, IL (Hooterville)
                    View My Photos
                    Local Time:
                    8:45 PM
                    Yes. those differences are just before the long spline where the yoke slides on.
                    • fishy68
                      16,761
                      710
                      Jan 11, 2005
                      View My Photos
                      Local Time:
                      8:45 PM
                      Yes, thank you Dave
                      • Agree Agree x 1
                      • Ghostrider 67
                        95
                        45
                        Oct 25, 2015
                        Local Time:
                        9:45 PM
                        Thanks everyone!
                      • j par
                        10,562
                        3742
                        Jul 2, 2014
                        Portland Oregon
                        View My Photos
                        Local Time:
                        6:45 PM
                        Let us know what happens.
                      • Ghostrider 67
                        95
                        45
                        Oct 25, 2015
                        Local Time:
                        9:45 PM
                        I will.
                        • Like Like x 1
