TF A904 reverse issue - band adjustment
Transmission and Drivetrain Tech
  1. dave225
    dave225 Active Member
    34
    77
    Nov 17, 2019
    34652
    Local Time:
    9:33 PM
    I have done some reading and it appears I can adjust my reverse band. The car is a 74 Dart Swinger with a slant 6.
    The transmission in the morning (cold) has reverse but it is weak and noisy. Shifting back and forth from reverse to drive a couple of times get reverse working just fine. After driving it the trans works fine all day and then starts over with the problem again in the morning.
    Will adjusting the reverse band remedy the problem? Fluid level is good and it shifts fine once warm.
    Thanks for the help!
  2. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    17,579
    5973
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    8:33 PM
    how is the shift into third gear(Drive) when cold? The hi-drum is used for both third and reverse. So if hi works fine, then
    Yes I would do a band adjustment first. But since is is noisy, chances are that the lining is possibly gone, and you will see it as soon as the pan is off.
    The Reverse servo gets full pump-pressure, usually about 250 psi, so if the band doesn't apply properly, it is usually because the servo is out of travel, or the band is toast.
    So time to take the pan off and look.
    But if the rpm flares on the 2-3 shift, then the hi-drum is toast, and the trans has to come down.A flare is when the rpm goes up instead of down during the shift, and when it gets real bad, you have to lift off the gas to finish the shift.
    • Agree Agree x 1
    • dave225
      34
      77
      Nov 17, 2019
      34652
      Local Time:
      9:33 PM
      The shifting throughout the gears is fine. With that said I do wait until reverse works well until I pull out of the driveway. It is possible that third has an issue. I think I will back in tonight and just pull out tomorrow to see how it goes through the gears cold. Thanks for your insight!
    • Murray
      Murray FABO Gold Member FABO Gold Member
      1,468
      933
      Apr 19, 2010
      San Jose, California
      Local Time:
      6:33 PM
      I think you have a common problem on Mopar automatics with cold starts. At rest, your torque convertor is draining back to the pan, so on cold starts your convertor is basically low on fluid. Most of us have learned to live with this little problem. On cold starts we shift from P, to N, to D, to N, to R, to P. This gives the trans the pathway and the time to fill the convertor. Then the rest of day it will be good.
      • Agree Agree x 1
      • tonysrt
        tonysrt FABO Gold Member FABO Gold Member
        622
        275
        Dec 25, 2016
        Northport, NY
        Local Time:
        9:33 PM
        Isn't this more of a problem with the 727's? I know my 71 340 was always a little hesitant in reverse when it was cold or I hadn't used the car for a week.
      • dave225
        34
        77
        Nov 17, 2019
        34652
        Local Time:
        9:33 PM
        Thats exactly what I have to do. Are you saying this is normal?
      • Murray
        1,468
        933
        Apr 19, 2010
        Local Time:
        6:33 PM
        I'm not really a tranny guy (others here are) but I have been told that a check ball in the front pump is the problem, allowing the fluid to drain out of the convertor when sitting. While not a "serious" problem, the cure is to replace the front pump and the check ball. Most of us live with it. Hopefully a real tranny guy will respond and clarify things.
        • Agree Agree x 1
        • fishy68
          fishy68 Tyr Fryr's Inc. FABO Gold Member
          16,908
          900
          Jan 11, 2005
          Central, IL (Hooterville)
          Local Time:
          8:33 PM
          It may be more pronounced in 727's but can happen with 904's too. It's usually because the stator and/or rings or the front drum are worn and lets the pump drain back. The 904 is the same design as the 727, just smaller
          In the case with the OP I agree with AJ/FormulaS that the issue may be related to the stator and/or front drum
          • Agree Agree x 1
          • Bakerlite
            Bakerlite Well-Known Member
            2,017
            197
            Nov 12, 2007
            Local Time:
            2:33 PM
            Could be hardened seals as well, since it works fine when hot.
            • Agree Agree x 2
            • RedFish
              RedFish Well-Known Member
              23,894
              2598
              Sep 5, 2007
              Local Time:
              8:33 PM
              Condition in my 67 904 is a little different. No reverse for a couple seconds then it engages hard. I think that hard engage is because the accumulator spring was removed. So I just let it idle in neutral a couple minutes. Problem disappears.
            • Oldmanmopar
              Oldmanmopar Going left turning right FABO Gold Member
              7,965
              3888
              Jan 8, 2009
              Danielsville Pa.
              Local Time:
              9:33 PM
              Wrong fluid to thick or its dirty with a bad filter. adjust the low and reverse band while in there. That noise you hear is the flat prop from the adjuster that holds the band because its loose. You may get some more mileage if you do this but when it falls out it usually takes out the case when the band starts spinning. Have the trans rebuilt soon.
            • dave225
              34
              77
              Nov 17, 2019
              34652
              Local Time:
              9:33 PM
              OK, I drove the car to dinner last night and then first thing this morning. Reverse engaged about 90% so I backed out of the driveway and proceeded down the street. It shifts fine through the gears with no flare between 1 and 2 or 2 and 3.
              I have never experienced the converter draining back in to the trans and causing this type of problem on any other car I've owned. I guess dropping the pan and adjusting the rear band is then next step. We'll see what happens.
              Thank you for your replies, I was hoping for someone having this same issue and the band adjustment was the remedy.
            • Oldmanmopar
              7,965
              3888
              Jan 8, 2009
              Danielsville Pa.
              Local Time:
              9:33 PM
              i just had this issue with a 904 in this brown Duster . The motor and trans had 30+ K from a 73 Charger. I installed it to get this car running and painted everything and added a 4bbl so all the 340 parts could be used.
              I dropped the pan drained the fluid ,Installed a new filter and it works perfect. I used a Auto zone kit with the rubber gasket and it kept dripping fluid. I thought it was the front seal installed wrong because it was dripping from the bell. I put it on the lift and dried it and with it on the lift and not leaning forward you could see it was the pan. Put a cork gasket in and no more leak. This 904 73 trans has a stall converter from the factory and works perfect for performance.
              • Like Like x 1
              • toolmanmike
                toolmanmike FABO Staff Staff Member FABO Gold Member
                46,935
                31225
                Jan 18, 2006
                Iowa
                Local Time:
                8:33 PM
                ALways nice stuff OMM
                I would drop the pan, adjust the bands according to the manual and make sure the linkage and kickdown are properly adjusted as well. You may have a converter drain back issue. I have 2 96 Dakotas, both with the A500 transmissions. (904 overdrive) One has issues in the morning and the other one doesn't. I just start it in neutral and it's ok. The 904 in my 70 swinger has the drain back issue as well.
                • Like Like x 1
                • Agree Agree x 1
                • CudaFactHackJob
                  CudaFactHackJob FABO Gold Member FABO Gold Member
                  902
                  307
                  Mar 17, 2016
                  Hemet, Ca.
                  Local Time:
                  8:33 PM
                  Start it in park. Put it in neutral for 10 seconds. Then try reverse. If that works, then I wouldn't drop the pan at all.
                  • Like Like x 1
                  • AJ/FormS
                    17,579
                    5973
                    Jan 19, 2014
                    Local Time:
                    8:33 PM
                    Most hi-mileage TFs of that era have this problem. But no one can say a band adjustment is THE remedy; it is only the first go-to, of the diagnostic procedure.
                    You could put a pressure gauge on the L/R servo port, and if you get 250 psi there at 1600rpm, instantly, then the servo will be at full travel, and then the the only known cure is to check/adjust the band. But if you drop the pan and see band chunks in there, or you see the band adjuster flopping around in there, or you manually apply the servo lever and it goes to the bottom of the bore, then you also know what you gotta do, and you didn't have to buy a gauge. By contrast, the gasket is super cheap, and if you buy a filter kit, the gasket is sorta free.
                    • Like Like x 1
