BIG DOG
While I had it on it's side wire wheeling the bottom I decided that there was a bit too much corrosion between the floor panels and the frame soooooo , I decided that the best way to get at it would be to remove the floor pan . With the floor pan gone I would be able to blast wire wheel clean up any remaining rust and then prime it .So where exactly do you stop? I couldn't continue knowing the rust was there.
