The horse is dead
How can you write a tech sheet that covers every aspect of installing high ratio rockers?
It would be damn near a book. It’s not a one size fits all install. He has no clue on valve stem height or anything else.
That’s insane to think he should write detailed instructions to install the rockers.
Oh yeah...if it is so complicated, why wouldn't there be at least a suggestion to check his website to download a PDF of the installation?
I just took a Quick Look at his rocker costs. I saw a little over 1300 bucks. Could be more expensive rockers but that was the most expensive ones on the first page.
No. Only the "cryo" versions.
Dave could write a book about how to install rocker’s and give it away for free with every purchase.
That is silly but some think that’s what Dave should do.
Are you Bi-polar? LOOK at the first quote at the top, then the one directly above.
Are you dense or do you not read well?
I’m saying your idea to write down how to install rockets is nuts. It would be a big book. That’s my point.
Since you are now the top basher, I’ll ask you this.
What EXACTLY could Dave have done to make a wrong that wasn’t his right with the OP.
Be specific.
I already stated it numerous times yet like it was from 2021 until late last year, SOME people are so blind, they cannot see what is obvious to others.
My comments in this thread got far more positive feedback than any of yours.
FACT.
Your opinion is in the minority.
FACT.
This topic could have been completely avoided with one simple and relatively easy policy.
FACT.
FACT.
FACT.
FACT.
I don’t give a **** about feedback.
FACT
The majority is usually wrong.
FACT
The only way to avoid this topic would be if Dave blew the OP, gave him double his money back and sent him a Christmas card every year with an apology for not treating the OP like a snowflake.
FACT
Here’s one more FACT for you. Your opinion is just that. It’s based on your own mental weakness, inexperience and fear of failure.
FACT
He ordered the wrong rockers .. he should have ordered 1,5’s they would have been plug and play!
No, he did not order the wrong rockers at all. Hegot terrible advice, or none at all.... it's the whole point of the thread...
But your turk friend, as always turn to then to about him...
Fortunately I don't need this much attention...
Something you might want to reevaluate giving assholes a pass, because they vote the way you do... that's syco...
Not a given, and 1.6's definitely aren't
That should be the point of the thread...
No one saying anything about his products...
Dave should have known that something was wrong when it was that far off, maybe a little rubbing and a little massaging, but not what the op was describing...
I pointed out the obvious problem with pictures about ten pages ago but now it's become all about your friend...
Come on, man....I was ready to give you some slack since it does seem like you try to help some people but it sure looks like you're doing the same things that got you in trouble here before.
I had to IGNORE that "Yellow Rose" guy because the argumentative theme that you seemed to often have.
Confidence is great but it is better when coupled with a bit of humility.
You continue to bash the OP while leaving no room to consider that it wasn't an "Inability" on his part but more of a lack of desire to pull the heads to make the modifications. It sucks to think you're right on track then get surprised by some part that (without any warning) only fits by modifying something else.
What you seem to miss is that not everyone is on the same level of skills or experience.
For an example....
I'm taking an introductory welding class at the local Junior college. Some students have had some experience before, most have not. We are all there to learn. Some guys can't even read a tape measure but are well versed in other things. I've welded off and on since the late 80s. I was a Carpenter for 36 years so measuring and layout is old hat to me. I don't insult the other students for what they don't know. I'm one of the biggest smart asses you could ever meet but I try to read the room and act accordingly. I don't insult those that are disabled or those that are trying to learn.
The OP wasn't warned or advised of a fitment issue. YOU think that everyone should know to expect that but clearly, that isn't correct. I didn't know either. I'm no idiot, I just haven't encountered it yet to learn from it. Would you berate a Chevy guy that rebuilds his first Mopar and makes a few missteps? The man may be absolutely rock solid with 350s and 454s but this Mopar engine is uncharted territory.
I won't IGNORE you yet, I'll see if you make efforts to help people more than annoy them. You do seem to have a great amount of knowledge that can help many other people. Unfortunately, your occasional rude comments are exactly why the OP started this thread about Dave Hughes.
you just answered yourself with the part you highlighted....... the OP does NOT have the SKILL or EXPERIENCE.
so how is this Dave's fault?
You know how I got my experience... by trying something and making a mistake and fixing it... i always call the professionals that I buy my products from for advice. On how to use them...
When I call TED and n at Portland engineering builders, he takes the time to talk over all the different aspects of what I'm i'm asking for and the same plan at Oregon cam grinding. He'll be on the phone with me for twenty minutes or more.If it, that's what it takes to make sure I understand everything.. completely walked me through degree in my cam. Does a matter of fact He's the one who brought up the subject and made sure.I knew everything before he let me off the phone...
D*** head Dave, told me to run my rocker up eighth inch gap underneath the shaft.. and was short with me on the phone like I was bothering him...
When will you people figure out?
He's a long winded poser with no car...
He's about annoying as that guy that asks all those questions and doesn't have a car and is looking for one... I put him on ignore... It's just too much..
i bought cam, lifters, intake, heads..... a lot of stuff from Hughes over the years. i had a few questions since i was very green in the engine assembly area. i called Hughes several times over 3-4 months while putting the engine together. a few times i talked to Tim but for the most part i talked to Dave. Dave is to the point and doesn't waste to many words. i understood he is very busy and has a business to run. he wasn't rude or pushy by any means. i took his advice and his advise was what i needed to finish the engine.
this is my experience with Dave and Hughes, not everyone shares the same as me.
That’s just it. I’ve said it multiple times.
This **** doesn’t just bolt on. What was Dave going to warn him about?
How would Dave know “how far something is off”?
It’s baffling how dull some of you are.
None of that matters.
Dave is responsible because he didn’t idiot proof everything for every situation and every variable that could happen.
It’s silly really that full grown men are blaming a guy for something that is clearly not his problem.
If you listen to guys like Jpar you can tell why. They blame Dave because they are in the same boat as the OP. They don’t have the skills to do the work so they blame the parts.
Hell, Jpar thinks the rockers are engineered wrong! How do you deal with guys like that?
OMG! only you would not get the hypocrisy of that statement!:rofl::rofl::rofl::rofl::rofl: I couldn't let that one go lol
Yeah, it's always nice that certain members get to drop politics into everything and yet they never get a time out for it.
If I called out Jpar for his politics I'd get a time out.
That's the FABO double standard.
Lol.. i past that picture around to my friends years ago.. funny...
For the record, i'm not from portland.. I'm from michigan....
I no longer live in Portland ether....
Only you are out here defending your friend, which, as always. Is defenseless and unexcusable as always...lol..
You might not be from Portland but you fit in there just right.
The only indefensible prick on here is YOU.
I've never put anybody on ignore because of there
Voting preferences... that's freaking childish...
Now lack of character.. that's completely different...
I'm not out here to prove how big of a d******* I can be. I'm here to maybe help as i've been helped so much by others here.. it's hard navigating that with this kind of huge blanket of negativity, one man cast on this forum...
I mean, he's got to have the record for being kicked off...
How can't that speak volumes..??
lol. You are the most politically motivated prick on here. That’s why I’m “toxic” according to you.
You are a sniping little clown of a man. You do innuendo and think it’s cute.
You are a vile, hateful person, who lies without remorse.
Anyone can go to the N&P and see who you really are. That’s a con man and a profligate liar.
If people only knew the lies you tell.
J-Fag is a fuckin idiot plain and simple. This is WAAAY of the subject, but, gives some insight to my observation.
When I was first selling parts here, I had a set of Lakewood traction bars up for sale. I listed the part number and actual pics of product. Looking up the part number, you would know that they didn't fit a Mopar. I never claimed or stated that they DID fit a Mopar. I took it for granted that most buyers check out stuff on their own. I had completely overlooked the Non-Mopar for sale section. Quite honestly, didn't even knew it existed at that point. J-**** comes on reaming me a new one, calling me a crook because I'm trying to pass that **** off as fitting a Mopar. Didn't even say hey there's this section to put them in. Just called me a crook right away. I called him a liberal pussy then. Imagine my surprise when I started checking out the N&P and caught some of his rantings over there.
I give people the benefit of the doubt, they can be a LOT different in person when they get out from behind the keyboard. Not him. I'm pretty sure we would not be friends.
When I was first selling parts here, I had a set of Lakewood traction bars up for sale. I listed the part number and actual pics of product. Looking up the part number, you would know that they didn't fit a Mopar. I never claimed or stated that they DID fit a Mopar. I took it for granted that most buyers check out stuff on their own. I had completely overlooked the Non-Mopar for sale section. Quite honestly, didn't even knew it existed at that point. J-**** comes on teaming me a new one, calling me a crook because I'm trying to pass that **** off as fitting a Mopar. I called him a liberal pussy then. Imagine my surprise when I started checking out the N&P and caught some of his rantings over there.
It’s all sad but true. The guy is a classless tool.
I can promise you he and could never be friends. I detest liars. He has ******* flat out lied on this forum many times and has specifically lied about me after I refused to lie for that scumbag liar.
Then he came on here and straight lied about me.
And this place lets him do his little hit and run bullshit lies, his snarky little remarks he thinks is cute.
Nothing cute about a liar.
How about it Jason? You want to tell everyone the specific lie you both know I’m talking about? It’s a classic lie. It’s about money and deceit.
Of course, if I post the lie I’ll get banned because the full grown men act like little bitches when the truth comes out.
Jpar is a LIAR.
Jpar is a LIAR.
He even cried, "I'm not liberal!" Yeah, right.....
I think the mods need to just shut this ****** down.... Put the horse out of its misery....
Nope, got nothing to do with defending a friend, he can stand on his own. I got an alert and just had to bust out laughing at what you said, too rich to pass up!, I got things to do, enjoy your evening.
