Small Block
Looking for a Jig that's used in cutting a rear housing. To the best of my knowledge there is a lug that slips into the ends you are putting on and also two lugs that are fastened down by tightening the bearing cap bolts at the center section. These 4 lugs have a hole drilled in the center to allow a steel rod to pass the entire length of the housing and keep it straight while welding on the new ends. Has anyone ever built one of these before? Where would a person buy one if he wanted one? Would anyone be interested in buying a jig if i made some. Cost is unknown at this time but i guess i'll get started on one. I have a lot of Danas that need cut down.
Small Block
Small Block
