magnummopar
I would like to know this $1500 recipe! The deal fell through so I'm still searching far and wide. Doesn't hurt to get a head start a parts list though..
2 parts EQ stage II heads
1 part Regrind roller
16 parts roller rocker/stud/push rod kit
mix thoroughly and bake tires at 450 for 1-2 minutes
FSM says do not reuse head bolts or manifold bolts. Intake are always toast due to threads on entire length of bolt corroding in aluminum. Magnum are different length than LA and would you clean old head bolts for $35? New, stronger than stock fresh bolts for that cheap=no cleaning old ones....
