VonCramp
My 340 was recently running beautifully. The next morning it wouldn't start at all. What I thought was a bad distributor is looking more like a bad timing gear. Just for the heck of it I checked the timing and went ahead and set it at 10* before tdc. I cranked her over and nothing. So, I moved the distributor a good 40* degrees or so and she kinda' fired almost starting. I got out the timing light and decided to see if it was jumping around. At first I couldn't even find it. I moved the light over to the passenger side. the timing mark was flashing way over by the passenger motor mount. It wasn't jumping around. Just way the heck on the wrong side. Any thoughts on how this could happen? I almost forgot to mention that when the motor quit running I pulled the distributor out of frustration and stabbed it back in later that day. Did I stab it 180 out? I sure in the hell don't know!
