Ddaddy
Just doing what I do
Gee, you win the spelling bee. And fail to understand auto-correct on electronic devices.Theres a d in knowledge smart guy....oh the irony....
Or the message given.
Ahhhh... good to know. Thanks Kim!My shock brackets took a week. Kim
You doing a thread on that build?Im about to dunk a crank that has been in a delapitated cardboard box out in the weather for 4 years....well see! As soon as I build a crank sized box that will hold the trashbag full of Vinegar. It must be wasted rusty, will take pics next week, while on stay-cation. BTW its a 360 turned down to 340 mains and neutral balanced IIRC. Poor mans 318 stroker using low comp 318 truck pistons.
Well, guess I'm odd man out. Have some brackets submerged since Saturday and really, no change.
Thanks George jets! I'll try the scotch Brite. I took a wire brush briefly to the one and plunked it back in... I'll clean them then shoot primer and satin black to finish them. They're the hose/brake line brackets for small bolt disc brakes.Wonder if you have an oil film on those brackets. Wash them down with Brake Parts Cleaner to get any oil off, then maybe even light wire brush them to break the surface, then put them in new 5% or 6% cleaning vinegar overnight soak.
Next day rinse them down with distilled water and a scotch brite scuff pad. Then final polish them up on a fine wire wheel on your drill press. Should make them look like brand new steel.
After the vinegar dunk and distilled water rinse and blow dry, the parts are so raw that they will flash rust. That is when I polish them up with the fine wire wheel.
Engine parts I put a coat of WD-40 on them and polish them up with a scotch bright scuff pad, then blow them down and wipe them down with some paper towels.
Coated and protected till assembly.
Here is a picture of the crankshafts after vinegar dunk and distilled water rinse and blown dry. As you can see, they flash rust real quick in minutes, so get some WD-40 on them to stop the flash rusting.
Flash Rusted
Before:
After:
They Polish up nice, takes a little elbow grease.
Is washing soda "20 mule Borax" ????
The only ingredient in 20 mule team Borax is a naturally occuring mineral called sodium tetraborate, Na₂[B₄O₅(OH)₄]·8H₂O.Is washing soda "20 mule Borax" ????
