MOPAROFFICIAL
If it has tits, it's a liabilititty.
I've been really busy lately. A lot of life going on...like most us i'm sure... and in between life battles...we might sit and ponder the projects plans n so forth. Right now Im putting my 340 back together at the moment and getting peices of the shelf to do it. I stripped it to a short block to do the heads and basically make upgrades.
I have a .030 over 70' 340 . It originally was out of a dual scoop 4spd dart that put a 360/380 crate in and then moved at to illinois about 16 or so yrs ago... anyways...I have a set of x heads i did up, 2.02 11/32 valves, had hard seats already...just had new guides and vj. I ported them/flowed them and they do 271-275cfm by .550 264-266cfm by .500 , 230's@.400 190's @.300 and so on. I pickes those up in 2002 and have ran them on 2 motors and went through them 2 or 3 times... i like fresh heads on every new configuration.
So i have a few cams..... about 6. Purples, schneiders, herbert. Though about using the roller from my 410...but...
I've choosen to use the engle .573 solid 110/252@.050 int closes @54 iirr...
I have a couple ld340, one ported some thw other stock, an old xcellerator, vic 340 to choose from tti's... should be a nice little rev'r with my 4 spd and 3.73 street gears.
Now the other day i bought something even though i told myself i wouldnt ... i bought a running .020 426 commando 1965 i think. came out of a belvedere... i dont know what im gonna put it in.. but i couldnt pass it up for the price... also i picked up another 4 ear 318 same casting as the last i bored 4.040...and i have another set of std 340 pistons laying around... might build it into a STOCK spec 340 ... but with these 302 heads i have 'the only reason i would use them for the amount of work to make them comparable to a stock j head' and put it in an abody for the wife... idk.. you know how it goes... sitting pondering what next.
I need to start liquidating extra **** im not using or havent in the 20+ yrs ive had the stuff. Everyone posts their plans and whatevers.. so there ya go.
