Thermoquad - Lokar kickdown
gerty
Burkesville,Ky.
Has anyone used a Lokar kickdown cable on a T/Q? Pics of the hookup method to the carb would be very helpful. Lokar's instructions are not much help.
Thanks, Bob
Yes it have and there product, pictures and directions are not for use with a TQ. Or OE AVS & AFB carbs.
The Edelbrocks can use the kick down cable because they use the throttle adapter. This provides a location for the cable.
PROBLEM SOLVED!
The adapter lever, I took and used its profile view to make a flat plate and drilled 3 holes in it. 1 hole for the throttle stud, 1 hole for the little hole on the carbs arm and 1 at the bottom for the lokar cable. I bolted said flat plate on the TQ's arm at the stud and a nut and bolt you need to source out from a hardware store.
Somewhere in this forum in my vast amount of posts, I have a picture of this on a OE AVS.
When I get home, I'll see what I can whip up for you.
PROBLEM SOLVED!
I kind of did the same thing with my Edelbrock as you did with your TQ, but the reason I made mine was for geometry adjustments over the Eddie bracket.
I can adjust the TP to react quicker or slower in the throttle travel as well as the amount of travel by changing where it is in a slot.
My first attempt at this resulted in a longer, wider lower adapter half just for that exact reason. And not knowing what exactly I was doing. First time was without the bracket in hand, just in my head.
(Leaving for home now)
Sorry for all those awaiting these shots. (Gerty) I have been snowed under so to speak.
These pictures apply to all the OE Carter carbs except a WCFB. I have not had the pleasure of seeing one close enough to know yet.
You will need snips to cut a
Aluminum sheet or mild steel
A drill and bits
2, bolts, nuts, washers.
First up is an OE small AVS on top of that old 318 Duster on the cheap thread I did years back. Lokar cables for throttle and trans. The OE carb doesn't have a provision for the kick down cable so you have to make your own adapter. E-Z, P-Z! This adapter was aluminum (.060 thick or so) I think though a mild steel plate would do just as fine. A small sheet can be picked up at the local hardware store, like ACE or similar. The hardware (nuts, bolts, washers) are a parts bin find in my garage thopugh I'm sure a hardware store like ACE would have something for you. Just measure with a mic or fit a drill bit into the carb's throttle lever for a approximate size need for the bolts to be used. 1 large and 1 small to attach the plate to the carbs throttle arm. The bottom hole is for the cable for the trans kick down. Approximate it's placement with the Edelbrock adapter. Which will not attach to the OE carb.
The same trick applies to the TQ. Though I can not find a finished picture, you can at least see that I'm just about done with this one. Just a quick drilling to make the hole for the Lokar cable stud. And I'm done.
Note the extra 4th hole onthe red adapter on the AVS. That would or could be for a OE return spring.
Note that the throttle stud is in place on the TQ.
Wow, what a great write up and the pics are excellent too. This should be in the how to section. Thank you so much Rumble.
Bob
Thank you and my pleasure Bob.
I knew I had those pictures. 10 years ago! LOL!
And now, to get the brain working, what design can you come up with. I was working on another one of those plates and though I would make the shape the MoPar omega "M" to employ.
Honestly I'll probably copy your design, I like it. The logo M would be cool but I don't have the skills. My wife is artsy smartsy so I'll put her to work. lol
Nice work Rumble.
I was thinking the Batman logo for one. :D
Aluminum frying pans with the cheap Teflon that is worn out make good materials also, so when they get retired and leave the kitchen they go into my materials pile.
Does anyone have the measurements where the 3rd hole would go? I just want to make sure I put it in the right place when I make this.
What your basically doing is making a flat version of the adapter part Edelbrock or Holley sells.
The measurement just about 2-1/2 inches (center to center) exactly, downwards and 3/4 of an inch rearwards of the top connection hole on stock MoPar Carter carbs.
Other Carter carbs used on other makes will vary there attachment points.
Nice work!
This is precisely what I just ran into, and determined I may have to make my own bracket from the Edelbrock adapter also. I'm surprised an appropriate adapter isn't 'out there' to buy.
64 Dodge Dart GT
'68 318 engine
TF 904 trans
I have the Lokar TC-1000HT throttle cable , the KD-2904 kickdown cable, and the SRK-4000 Throttle Cable Bracket
From what I can tell, I may also have to make or modify the Throttle Cable Bracket because it is NOT LONG ENOUGH to reach the extra width of the ThermoQuad Carb. I think it would be easy to bolt on a short extension, just won't look as tidy. I highlighted it from your own photo. Is there a longer bracket to buy or did you just make one that was a little longer than the SRK-4000?
Thanks. That is the stock Lokar throttle bracket.
Nice work!
64 Dodge Dart GT
'68 318 engine
TF 904 trans
A “How to” pictorial of a Thermoquad & Lokar bracket.
The metal plate was simple .060 (IIRC) picked up from the local hardware store. The throttle lever arm is approximately the same length top to bottom as would any Chrysler Holley/AFB carb adapter.
The TQ has two holes drilled into the throttle arm lever. Do the same rod the metal plate. The throttle cable stud is one hole as seen. The second hole, use a small bolt and nut, washers/lock washer optional rod the smaller hole. Not the plate will not rotate.
The adapter plate for the throttle arm has a “Tail” that hangs low. Going pretty much straight down. This lower hole is for the Lokar transmission cable. It’s distance is approximately the same distance away from the throttle cable arm as the common adapter is.
You may find a minor issue with the Lokar horizontal adjustment screw.
Fantastic. That is exactly how I had planned to approach this, but it is nice to know someone has already been successful with it AND shared the pictures!
I'll be sure to measure my throttle cable travel as well as the kickdown travel to tweak the geometry before I make it all final.
Wish me luck, I'm going to get started :-)
Thanks for the quick and thorough response!
Your welcome! Glad to have helped. Take some pictures!
The pics from way back. Both adapters have been working fine, but now it’s time to improve it. I don’t get enough ‘pull’ on the throttle cable to reach WOT and open my secondary throttle plates.
It’s not a linear pull due to the changed angle at WOT.
So I think I may have to add a ‘round cam’ (blue) so the cable (orange) can pull evenly at a 1 1/4” radius from idle to WOT.
Or maybe just get a different carb!
All TQ’s except the Race and the over the parts store counter Replacement TQ carb have the same arm lever and hole position. If your not getting enough pull on the cable to get wide open throttle, the cable will have to be move backwards towards the firewall for more room.
I don’t suggest wrapping the cable up and over since it adds complexity to what should be a simple project. You would have to create a “U” channel and bend it with enough distance needed to get the wide open throttle position. Then attach it.
It would be easier to cut a new piece and relocate it on the throttle arm.
Easier than adding a cam is to lower the throttle cable housing on the extension brkt so the ratio starts out greater and does not fall as much at WOT (like the aftermarket brkt housing height). With enough ratio, to minimize the cable rubbing at the housing entry, the height of the housing should be split between ball stud height at idle and height at WOT or the brkt can be twisted to change the housing angle.
I have plenty of cable travel, so luckily I shouldn't have to move the bracket back towards the firewall. The issue is loss of leverage at WOT due to the diminishing angle, so what MV8 suggested is an option to try. Or make a new throttle shaft lever so I can move the ball stud forward towards the radiator, and get more balanced arc from idle to WOT.
But it's gonna be a while. Wife and I have our first little hometown car show this weekend so I'll be polishing wheels, buffing paint, treating the ragtop and back window, and....and..... And no, we will not be opening the hood or the trunk!
Thanks for the good suggestions. I'll post once I fix it and move on to something more interesting.
