danielb927
So, I went out for a cruise today (first of the year finally!) and remembered how the secondaries on my carb don't work. I'm running a 360 with a thermoquad on it. I played around with the carb today, I don't think there is a vacuum leak anywhere (about 14-15 at idle, even with about 4 hoses plugged up with screws). When it's just sitting there, I can get the secondaries to pull and sound right. I looked in the engine with the filter off so I could see the carb. It has mechanical secondaries so I know when I get to the point of opening them. So, just sitting in park, I gave it full throttle, I could see the secondary air door flap down and it sounded good about 3 out of every 4 tries, when I did that though I had a thin smoke come out the exhaust and it smelled noticeably different. It stutters or almost dies when I get into the secondaries while driving though.
Other Engine characteristics: Hard to start (pump the gas when cold, floor it when warm) , Smells like gas while running (exhaust and engine compartment both, I think) , Really high idle while cold (I can drive 30-35 mph down the street with my foot off the gas before the car warms up).
My thoughts are:
Fuel Filter needs replacing?
Some other fuel system problem?
Carb needs a good cleaning, specifically the secondary jets?
Anyone have some better advice? I feel like I'm kind of shooting around in the dark without a real idea of what might be the problem.
My thoughts are:
