[Found!] THERMOQUAD TO SQUARE BORE ADAPTER WANTED
CFD244
"THE NEW OLDSMOBILES ARE IN EARLY THIS YEAR"
Northern Ontario, Canada
Hi Folks
I want to run a TQ on a Edelbrock square bore Performer and need an adapter. Anyone got one for sale?........Hopefully in Canada?
Thanks FABO
For people who don't have the correct carb for the manifold maybe ?
Otherwise you wouldn't need an "adapter."
Funnels are made to work in one direction but I guess someone can figure out how to use it upside down.
Go back to a post by Bill Crowell on Feb. 3, 2021- Square-bore vs. spread-bore. I posted several pictures on the difference between a Q-Jet and a TQ carb adapter-they are different. Edelbrock has both, but they use the same picture for the Q-Jet and the TQ adapter. Back in the day-the late 70's, I was running an adapter on an Edelbrock TM5 with a 850 TQ on my 68 340 Dart. I sure didn't seem to be lacking in flow, it ran very hard!
Also affects performance like a spacer!
Properly engineered for spread bore.
I have run this adapter with a paper gasket under the carb, and can tell you that in this configuration, the secondary plates hit the aluminum body and could not fully open. I installed the thick Carter gasket and away she went.
I can also tell you that the TQ is way more carb than the 318 mule can use, so it will work thus, even funneled down and "choked".
But I sure wouldn't run it in this configuration, ever again, on my 11/1, 360. After I installed the correct spreadbore intake under that 850 of mine, it was a different engine. and, when the Airgap came out, I bolted one of those on, with a Holley, and never looked back. I tried various sizes, and settled on a 750DP.
For testing purposes, it will be fine; and IMO, making sure the carb works, before breaking in a fresh flat-tappet cam, is a really good idea. As to testing the ignition, well, as long as it revs to 2500 and doesn't drop sparks on the way to the plugs, any old ignition will work for break-in. But again, knowing that the ignition will light-off, right away is of great comfort to me, and to the life of the new cam. Good on you for thinking ahead. Happy HotRodding.
Now, Whenever I break in a fresh cam, I take the thermostat out, and replace it with a restrictor, I use straight water, and I keep running water handy; I friggen hate worrying. I make sure, that the daymn cooling system also works, and after the new engine lights, without regard for the actual numbers, I reach back there and advance the timing until the rpm peaks, and then let 'er fly. This will help prevent overheating that can happen when the still burning hi-energy exhaust gasses leave the chambers, running right below the water jackets, at some 500/600 or more degrees. Better it is, to get the temp down a couple of hundred, while still in the chambers . After the cam is broke in, I can return the timing back to sanity.
