I agree that 400 slugs can be retardedly expensive by KB. Turning a 440 crank down may be cheaper LOL. Then theres balance. I don't know what'll take to balance that all up.
Yeah. I've got a little bit to trade and I'm sure I'm going to have to. like 3 sets of J heads (probably only cores...) and several complete motors.
I really like the idea of a fast revving and high torque. I'm going to have to see what else I can dig up in the garage.
I suppose it's always an option to stick with manifolds for now then when funds come my way swap to headers.. even though it'll probably be kind of a pain lol
How much would a 440 crank need turned down?
After a little browsing I found
440 crank mains - 2.75"
400 crank mains - 2.625"
With a 0.125 cut needed, couldn't I almost find a 440 crank that spun a bearing that nobody really wants and use that?
Sounds about right.250" from the counterweights
Sounds about right.
For the cost of the KB 400cid slugs and a balanceing, he could be up and running quick and cheap (Except pistons cost. What was it?)
The extra work of the crank can depend on cost. It is a widely vaiable cost. Just things like where you live, one machinest vs. another, material of crank, int. vs ext. balance. Machining journals down. etc..
While it COULD be done cheaply, I've never done the homework on it. Fast01 ditched his 451 w/cast crank in a heart beat flat and redid his entire engine over. The 451 set up is collecting dust right now. (Hummmmmmmmmmmmmmmmm...evil thoughts.....)
This is exactly right. I can get a balance done for 250 plus the cost of Mallory metal. That's dirt cheap compared to some of the other charges I've seen around the country. I don't get it. It's the same job whether you're in tinbucktoo of Macon, Georgia. It just doesn't make sense. Also, unless you're in a big hurry, i recommend just waiting until you can afford what you really want. Nuthin worse than havin a beer one night wishin you had built somethin else instead. I can surely see trying to internally balance a cast crank getting expensive because of all the metal involved.....but it can be done. I've done it. I did it with three stroker small blocks with that cast steel crank. Was a touch over 300 each time. I am just going to do my stuff one system at a time. Crank work, then the rods, then the block. A cam bearing tool you can use for damn near any engine ain't but about 150 bucks. You can install your own cam bearings and some for friends and make up the cost for the tool real quick. then you got that to do it yourself. Freeze plugs and oil gallery plug installation could literally be taught to a chimp. Just like basic cylinder head work. heck, maybe I need to document my build in a thread here and show yall how I do it. Might be good to show that you don't need a machine shop for every single thing. It'll probably be a while before I assemble, but I'll be glad to do it.
...........Just buy a crank from 440 source, it will drop rite in as its made for the 451 application...........kim.........
Oh...the 440 source crank is 700 bucks.
Thinking of going BB in my dart, but I have to many options.
What I currently own:
400 BB (not sure on year but I want to say it has a 2bbl intake on it)
My dart (currently 318/727 drums all the way around, but I have KH disc setup almost ready to go on with sway bar and a little bigger torsion bars)
What I can get:
383/727 (for free. I'm not 100% sure on the condition. It's been in a field for quite some time. It has 1 aluminum head on it, the other was destroyed during removal. I'm not sure if the short block will be salvageable or not because of exposure to the elements but it and the 727 are free.)
I also have the hookups on 4x 440's unless they have moved since I've last talked to the owners. None of those will be free (what should I expect to pay?) I believe 2 of them to be complete (running?) motors and 2 of them are disassembled (again, I'm not sure on the years)
What I want:
I'm not sure what to reasonably expect. I know I can't have it all, but I would like to build the motor/trans and get it rolling on a tight budget. Ideally, I'd say 11's would be awesome though it will see more street than strip, so a little reliability would be nice.
If yo can get the 440's, gettem Find out now. Nothing like cubes!
If you can get the 383 free, use the crank out of it in the 400 and get 400 slugs, balance it and go from there.
OH! 2G's aint enuff, but get your shortblock in order and done right, you can allways upgrade other parts from there. Once you have a good solid foundation!!!!!!!!!!
IDK, sorry.I just hope some of them are decent priced. What should I expect to pay for a running/nonrunning 440?
A 383 aint no slouch ethier, but a 400 has just a few more cubes. Everything on it is good to use.I'm getting the 383/727 no matter what. So many possibly valuable parts there to use or sell. Wouldn't the 383 crank need work as well for it to fit?
Wouldn't the 383 crank need work to fit what? A chevy motor?
It's the same crank as the 400 only the 400 is cast!
If you have a 400 and a 383 crank, get the balancer from the 383 crank. It's different than a 400's. Slam dunk the 383 crank into the 400!
You need a book on MoPar big blocks. Go to a place like, umm, Manciniracing.com and get a engines book for the big block. It'll help stop your head from spinning around soaking up info that doesn't apply or that is needed.
No, it's really not, but its what I've got for now. And that is the plan. I'm definitely going to run iron heads and may stick with manifolds for now.
Theres an old saying, you can't exceed the speed of your wallet and your wallet at 2K is slow. Just do up the short block and go from there. That'll cost ya 2G! done right!
IDK, sorry.
I'm not really that sure where I read/misread that about the cranks... And while I was digging the 400 out of the shed, I found what I believe to be a forged crank from a 383. Mains are the same dia. as the 400. It had a timing cover sitting right beside it with a neutral dampener and some pistons that are slightly smaller than the 400's and a little shorter rods.
I ordered "How to build Max Performance Mopar Big Blocks" today... A lot of people talked like it had some pretty good information in it.
Yeah.. Heads/exhaust manifolds can be swapped out later without to much pain.
I freakin love this thread! I would either build the 383 or drop a 440 in it! Ain't no replacement for displacement!!!!!
Haha glad you like it. Hope it has provided you with some information.. it sure has for me!
If it's a flat tappet cam, I don't recommend it. I know the concensus from the experts is that you can run a used flat tappet cam with new lifters, but cams are cheap. I never have taken the chance. Certainly doesn't mean it cannot be done. A roller of course can be used again and again.
Oh, and if you've not read this, you need to bookmark it.
http://www.arengineering.com/articles/articleframe.html
Good stuff there. You'll not regret spending your budget on the 451.
