tie rod end install
trbodrt
so. cal
I've had my front suspension on a 72 dart apart for a while and want to make sure i have it right. Where the inner tie rod meets the center link which way should it be installed. any pics would be of extra help. thanks.
Through '72 the idler and pitman come up through the bottom of the center link. Later years, they're opposite and the center link is different. All of the holes are tapered so the tie rod ends can only go in one way.
as said..the tie rods point towards the rear of the car....by pointing the treads point towards the rear of the car....
looked this morning at 71 dart to make sure...
threads of tie rods point towards rear of car, got it. thanks a lot guys, i appreciate it.
