Time to get started.
Kudos to H.H.. 96 degrees? Literally ,keep your kool M.M....
Doing my best :glasses7: Looking forward to setting up the gears and putting it in :glasses7: then I can have my drive shaft built to the right length :color: A little at a time in this crazy Arkansas heat Abodybomber :D
Ok :glasses7: Time to get started on this rear end, I have learned that this 2.45:1 gear 8 1/4 rearend will be a great driver anywhere I go :glasses7: Now to get the carrier bearings installed and axle seals, bearings then on to some brakes :coffee2:
Quote from a member here in 2012 = For what it's worth a build date of 9/73 A Body 8.25 has a casting number of 2852905
Cool, glad it arrived safe! Pete said you can wax the wheel and it will look even better, I still need to wax mine. Just shoot him a PM and he can tell you more about the wheel. :glasses7:
Mike, if that plastic spacer that the horn cover snaps into doesn't match the color of the wheel, send the spacer here to me and I can paint it to match. I left mine original and it matched pretty good, yours might too. I forgot to tell you to send that with the wheel......
Thank you again @FISHYPETE
