dustermaniac
Senior Member
Just replaced the cam, lifters, pushrods, distributor and heads in my Duster. Everything has gone well in the tear down and assembly process. Old timing chain (Double Roller) had a bit of slack when removed. After I put in the new parts and rolled over the motor with a breaker bar, I can hear a small "clicking noise" sounds as if it is coming from the timing chain. The valves are all opening and closing when I roll over the motor by hand and the pushrods are all moving in tandem with the cam lobes. The noise seems to go away after I roll it over a couple turns. The camshaft is set at 0 on the timing marks. The chain was tight when I lined it up and installed the sprockets and chain. I am not sure if this is a major concern. I did use a straight edge after I installed the gears and chain and they look straight on the straight edge. Any assistance with this is appreciated, Thank You
