What is the timing degree on a freshly rebuilt 318 with rv cam, bored .30 over on pistons holley 600 cfm 4 barrel on a 1975 motor
I don't think that much, with a so called RV camprobably around 14-17 initial , 34-36 full mechanical advance and 50-54 cruise vacuum
Probably a little much.....unless you're using full manifold vacuum on the vacuum advance. We can get you closer if you post the cam "SPECS" instead of "RV cam". If that's all we have, your answers will be just as vague. Hit and miss.I have it at 28° with a vacuum advance distributor
You sure that's not 204 and 214? ....and I assume it's on a 112 LSA? This works a lot better if you supply all the information.200° - 215° duration based on .050 cam lift
| Advertised Exhaust Duration | 288 |
| Advertised Intake Duration | 278 |
| Cam Type | Hydraulic |
| Computer Controlled Compatible | Yes |
| Exhaust Duration at .050 inch Lift | 214 |
| Exhaust Valve Lift | 0.443" |
| Intake Duration at .050 Inch Lift | 204 |
| Intake Valve Lift | 0.421" |
| Lifter Type | Hydraulic |
| Lobe Separation | 112 |
That's a very decent grind for a street engine. That's what I thought it might be.
Advertised Exhaust Duration 288 Advertised Intake Duration 278 Cam Type Hydraulic Computer Controlled Compatible Yes Exhaust Duration at .050 inch Lift 214 Exhaust Valve Lift 0.443" Intake Duration at .050 Inch Lift 204 Intake Valve Lift 0.421" Lifter Type Hydraulic Lobe Separation 112
That sounds like the right spot. Ported vacuum. I would recommend that for a very mild engine like this. I would back it down to maybe 18 degrees initial and see how it performs.I have vacuum hose plugged into the port on holley 600cfm carb at right top side of front fuel bowl going to vacuum advance on distributor
Impossible to say, since you never said what your problem is.Do you think it will fix my problem
start a 5 then dial it in by earWhat is the timing degree on a freshly rebuilt 318 with rv cam, bored .30 over on pistons holley 600 cfm 4 barrel on a 1975 motor
