Pumpkinduster
Hey all. I am working on my 318 in my 74 Duster. I’m in the process of switching to the hyper spark system. When I found TDC (this is a running engine) I noticed that my distributor is more pointing between 3&5 spark plug, had compression in the stroke and the balancer is at 0 with the timing mark. I have 10*. of timing advanced.
The first two pictures are at TDC and with the distributor it has been running. Next two is 10 after TDC
when I dropped the Hyperspark distributor in it came out the exact same spot.
If I roll the motor a little more where it is marked at 10* BTC it’s looking closer to the the number one cylinder. So I’m trying to figure out with installing the new distributor at TDC why I’m not pointing to cylinder 1. I know the distributor will have to be phased but that should only be after the rotor where I needed it. Any advice, I have a comp cam and a high volume oil pump. Should I just spin it over again until it’s back to TDC like before and just pull the oil shaft and rotate it until I get it where it needs to be?
