Torq Thrust wheel sizing
MOPARJ
What can I upgrade now?
Thousand Oaks, Ca
Currently running 15" cragars on my 73 Duster. Not sure if they are 15x7 all of the way around, or 15X8 on rears. Front tires currently are 215/60/15 and 255/60/15 on rear. Looking to go to traditional torq thrusts instead for wheels. Should I use 15x6 or 15x7 all of the way around or use 15x7 in front and 15x8.5 in rear? 3.75" backspace? I plan to use the existing front and rear tires.
You are going to enjoy the Torq Thrust aluminum wheels, much much lighter. You are going to notice a performance boost, less rotating mass (weight) to spin up.
Easier braking too, less rotating mass to slow down.
Less Rotating Mass definitely = Performance Boost
For those that want a good performance boost and make your ride look nice in the process.
___________
Have a smaller displacement engine, all the more reason to do it.
Win, Win . . .
15 x 8 rears, 15 x 7 fronts
