Torque converter prefill
JaysNMDustr
New Mexico
Is it neccessary to prefill oem torque converter before reinstalling it and the 904 transmission? TQ was emptied and flushed when trans was rebuilt. Engine is /6
yes you must prefill the converter prior to install. otherwise the front pump will not have a prime.
I have installed a couple of converter and never prefilled them...and everything worked fine...
I would recommend that you put some atf in the coverter...and I would have the trans in neutral went i started it up.
Not really necessary, but pour 1 qt in. Lube the shaft so it doesn't burn up the seal. Early ones leaked back overnight anyway (how would I know?). If you put in N it refills much faster. There is a Transgo fix for that. Make sure you fully seat the torque converter. Keep rotating and sliding in and out until you get the 2nd clunk. The bolt-up tabs must be >1/2" back from the front surface or you will ruin the front pump (how would I know?).
