Torqueflite 727 and Neutral Safety Switch
Alex69Dart
Active Member
Los Angeles, CA
hello!
I recently purchased a new shifter that has a built in neutral safety switch and reverse light switch. I have a TF 727 with the 3 pin neutral safety switch on it. Do I need to still wire up my shifters switches? Or will the transmission do all the work for me? Thank you in advance for any help!
I’m not a tranny expert but assuming you have the 3 pin connector stock pigtail already In your car you won’t need to do anything with the shifter switches.
The Chrysler OEM trans mount switch is very durable and gives little trouble. I would use it. the only downside is that 'with some' race car wiring schemes, this still requires you to use some sort of relay for a 'starter relay'. Minor problem, to me
Mine is a factory style wiring set up so hopefully I won’t have any issues!
