Hello fellas,
I finally got to out a few miles on the Dart this year as well as hit the track. While I was happy with the performance at the strip, the road manners are a bit sketchier that I prefer. Here is my current setup.
72 Swinger:
440 with Aluminum heads and accessories
Battery relocated
727 with 3.73 rear
Flaming River quick ratio manual steering box
4 wheel manual disc brakes
Suspension:
Slant 6 Torsion bars
QA1 upper and lower control arms
340 rear springs with offset shackles
Competition Engineering adjustable shocks all around
Wheels and tires:
205/60r15 on 15x7
255/60r15 MT ET streets
How much perforce do I have to give up at the track to get a decent ride and handling? What components will give the best all around performance?
My dad is switching to a rack/pinion coilover setup on his Drag Week Demon, so I will be snagging his adjustable strut rods. Will a front sway bar make a difference, or front/rear combo for that matter? What Torsion bar size will help ride/handling, but not totally ruin the performance at the strip? Are my drag shocks a big reason why the car feels so sketchy going into corners? Realistically, my car will only hit the track a few times a year for fun.... so I want it to feel fun and safe on the road. From all the suspension threads I have read, my handling/grip will be limited by the tread width of my front tires. I know you can fit some meat up there if you go up to an 18" wheel, but that is not the look I prefer on this build. 17" would be max diameter, but if memory serves correctly... I won't gain any extra width with a 17" wheel over a 15". So the next question would be what is the meatiest 15" tire I can fit up front on a 15x7 to make the car a bit more surefooted?
Thanks in advance for the help!
72 Swinger:
Battery relocated
727 with 3.73 rear
Suspension:
Wheels and tires:
205/60r15 on 15x7
