crazy 340
I know its been discuss alote BUT
I reinstal the front end of my duster with my new
QA1 K frame
but now the torsion bar key (the other part that adjust the suspention with bolt )
where the bolt adjust the suspention
that key or adjuster when the car hit a bump it come in contact with the frame
the adjuster bolt is about 1 inch out when the suspention is set at the right high
and its low I prefer it that way not as a low rider but...
do I need to undo the lower ball joint, torsion bar and push down on the lower
control arm to be able to index the torsion bar to get more lift with the adjuster
hope you can understand what I need
thanks Bob
QA1 K frame
thanks Bob
