Cuda416
Installed new poly bushings and new pivots on our LCA's and things went well. Everything moved great etc. Mounted everything up today, torqued the pivot nuts and now the torsion rod "socket" and adjuster arm, won't budge. Seems like it just needs to be "worked" and get grease into it but wanted to make I didn't mess something up. Is it normal for these to be so tight at first?
