theothergarth
I have a 74 Duster with a 318 (bored .40 over) with a Comp Cams Xtreme Energy (XE275HL) cam (Duration at 050" lift: 231int/237exh). The transmission is a 904.
The 1st problem: The car is up on jack stands currently. When I have the motor running in park it idles fine. When I put it in drive the wheels spin fine. If I apply the brakes, the motor will stall. It's like braking a manual tranny car without pushing in the clutch. It seems to me the torque converter would be the problem here. Any opinions?
It is not a stock converter, but if I need to replace it, I would like to pick the correct stall speed. I am thinking 2500 or 2600 RPM. This will be a street machine. Any opinions?
