This all happened a couple of weeks ago but I have been on vacation so I have not been able to post about it.
Here is my setup. 360, 400+ hp and 400+ tq, 727 with manual reverse valve body and billitt servo, 2800 stall convertor, B&M Mega shifter, 4.10 gears with spool.
I rebuilt the tranny about 3000 miles ago.
I was at a local cruise night and everything was working good. I did get on it a couple of times on the way to the cruise night and all seemed well. I headed for home and when I started to gear down to turn in my driveway second gear felt wierd, sort of like it was stuck in 2 gears at once. I wasn't moving very fast so I shifted to first. The back wheels just locked up. Keep in mind I was doing less than 5 miles an hours at this point. The car wouldn't move if I hit the gas, it would just torque up on the engine. Put it in second again and it would move but it was like it was in 2 gears again. I went to third and all seamed well so I limped in the driveway. I thought it might be the shifter out of adjustment or the cable gone bad, but everything looked good there. Now after playing with things there is no park. I can't even unhook the shifter and get to park by moving the lever on the tranny. It just won't go there.
Any ideas of what I should look for?
Jack
Jack
