mikess68
ok, 72 dart 318 added 4bbl the trans shifts but runs too fast before shifting. the rod is adjusted as far as it can and it needs about 1 inch to put enough preasure on the rod to make it shift quicker. where do i find a a longer rod or any tricks you know of. there is not another hole anywhere i can the it closer. so a longer rod would be good. the kick down rod is also extended out as far as it can go. >
