rick1062
Active Member
Hi all,
We are working on a 1965 Barracuda, 273, 904 auto.
It seems like after it is parked a few days, the trans level actually increases. If I check it without starting the engine, it will be far above the full mark. But, after starting it up for a few minutes, the level looks normal again. Is it common for the torque converter to drain back to the trans so it appears over full, then after starting, it is pumped back into the converter which makes the trans oil level read correctly again?
Thanks to all,
Rick
Thanks to all,
Rick
