Thanks, for the Compliment Tony,
I have found differences in shields,
that make fitting, fun
I'm going to attempt to salvage a old, broken post of mine.
CSI vs TCI
http://www.forabodiesonly.com/mopar/showthread.php?t=276915
does one fit better than the other ?
haven't measured or fitted yet,
the csi appears taller and wider
Will there be any clearance issue between the factory floor and shield
want to install the eng/trans with either shield
don't want to pull it back out to create clearance at the floor
did some more checking
tci will set inside the csi, the mounting bolt are 1" difference (csi taller)
csi wider
csi bottom shield (wider, front to rear) covers more area.
tsi upper shield wider (front to rear) covers more toward the front
I used the TCI- in the 70 Dart> SB/727
the CSI fit the 518 better,also cleared the JW bell better (for Big Block) since I had to make room for the over drive, It didn't matter it was taller and fatter>> LOL
edit:
the 72
front floor pans, needed replacing.(rust)
that area is still stock,
only the tunnel is raised
