moparspares
I have a Derale Transmission cooler that I want to mount Vertical and NOT across the radiator as it has AN inlet and outlet which I would like facing downwards for neatness of my braided lines. Standard hard lines obviously were run as flat as possible to the radiator so was wondering if there would be any problem with pressure from trans to constantly feed around the cooler.
