It's amazing the crap I don't know. I tend to learn what I learn really well, but never venture outside of that and learn anything else. That's where you geniuses (or is that geniuii) come in.
The ole Scamp seems to want to puke every fluid. So now I'm dealing with the coolant. As I've been having a bit of a coolant leak that I couldn't tell from where. But it looked like about 2/3rds of the way down on the fan side of the radiator. So I pulled off the radiator and took it to a recommended radiator repair shop. They showed me their process procedure and equipment. And pressure tested it. Turns out it was fine where I thought, but the top part near the radiator cap had a crack and was leaking. So, I guess the coolant was running down the radiator making me think the leak was 2/3rds the way down. He said it would be an easy fix.
While there, I was talking to him about the transmission cooling part of the radiator. He said he thought it was better to run the transmission fluid there, especially in times of idling in traffic (which I will rarely or never do, as this is not a daily driver). My Scamp has a transmission cooler below the radiator and it is obvious it is not original with the car.
My question is … would I be better to plumb the transmission lines into the radiator in addition to the auxiliary cooler? Or just leave it as is?
