I can pick it up with a complete 318 for 800 and I really want a manual trans in my duster but don't want to get in over my head.It's an A/F body A833 for sure
Agree...looks like an overdrive.Looks like the large bearing retainer so OD trans is likely
tell us all the numbers from this raised pad on the side.
The trans comes with an engine as well not sure if he has a bellhousing as wellThere is a bit of work....tunnel, installation of the z bar linkage, installation of pedals plus parts - bellhousing, clutch and TO bearing, shift rods and shifter. I believe the OD trans has the low 3.09 first gear. Do you know what shape the A833 is in? Your crank needs to be able to accept a pilot bushing too....not sure if they are all drilled for one or not.
That raised pad will have stamped info. Hard to get a good photo. Write it down and post it here fora decode.
that raised casting number doesn’t mean much.
