Transmisson leaking problem
75dartser
Active Member
Hi everyone i have a it of a leak problem with my tranny. I recently Installed a new exuast system on it. The exuast system is dual coming off the manifold. Once the exuast was installed after 10 mins the tranny starts leaking and it will leak it dry. Does anyone know a way to fix this or help?? thanks
Hi,yes there is a fix,but first we must identify where the leak is,since it didn`t leak proir to the exhaust installation,it was likley caused by something getting bumped or moved maybe a cooler line nut?>best thing to do is put a clean piece of cardboard down under the car and takenote where the fluid is escaping,front,rear,left right,then you can make the corresponding repair,good luck.
If it leaked dry, then you should have a noticeable puddle and be able to spot it. I would think the lines leading to the rad have been bent, moved or undone, causing the leak. When you say front, do you mean front of the tranny, or front of the car?
