Trough drain tubes and the drain areas for 69 Barracuda Vert.
Mike69barracuda
Harrisburg, PA
I need some photos showing where the drain tubes attach to the vert. trough for a 69 cuda.
I took my well liner out to clean it and see the trough but no tubing. I thought a tube runs though the passenger side rear fender? The front of the trough.............Does it have tubes? My trough is opened and drains down..............Pictures would be great! Thanks
There are no tubes. The water runs down the channel and drips/runs into the quarter panel and out the rocker panel drains.
yep same as front. Water and nasty that drains from ends of cowl runs down into the dog leg section of front fender. All we can do is keep all of the drain holes clear.
