Mrmopartech
This rant is about weather holley has started out out sourceing there O-rings to china and causing pre-mature failure to the ring and causing need and seat failure to the carb causing flooding and fire.I say this because a buddy ford falcon 65,has a great little small block in it.Ask to rebuild the carb last year and re jet it and set it up,no big deal and I get it done and run the car and it,s perfect.he starts it up a few times to move it and do the finishing touches and thats it,moves the car out of the garage 3-4 times does the work and back in,NO BIG DEAL RIGHT.Today he does the same thing,complete flooding and back fire and fire under the hood,I will also mention it was a new paint on the car,WAS.After calling me I rush over and take the carb apart,and both needle/seat assembly,s,the O-rings have turn to dust,and shreded with small particals through out the carb,so I warn you now and please check the o-rings big time as this is no where near normal for any make or brand,and please if they are buying from china,we need to do some thing to not let our cars/trucks burn up because of a .10 cent o-ring,mrmopartech
PM me if you feel you have had the same type of situation so we can call them about this,mrmopartech
