Alan K
I have a 74 Duster 360 with tti headers, the car has its stock fuel tank, and also the mp offset spring hanger kit, what systems will fit, 2.5HX or 3.0HX
thanks for the inputI know the 2-1/2 fits but do not know about the 3.
that would be greatMy '68 has a full 3" TTI w stock tank and rear spring location. The only tight spot is where the tubes bend around the front corners of the fuel tank. There in plenty of room along the sides of the tank. I also used that stick on aluminized heat shielding on the tank where the pipes pass by it.
Remember, the tube is only 1/4" larger diameter on both sides, for 1/2" total.
The car is over in the next state getting body and paint right now, but I can get you some pictures in a few weeks if you need them.
I was hoping you would chime in. I know some A bodies have a narrower wheel well than others. Just don't know which ones.
