j par
Yes no problem on the street long drives.
so
can you drive it on the street or long drives ok
so
I don’t know who this clown is but I ain’t laughing at you.
Ummmm, you calling me a lady?
Are you including me in the “nay sayers club?”
IMO, 400hp is low powered. Besides eye candy, I do t see any sense in spending for 2 carbs and an intake he does t have to make the power sought.
It does by a ton. That intake is 400hp capable.
So your disagreeing with a tunnel ram is a expense he can live with because the current 4bbl. intake is sub par?
sorry guys not trying to start problems. if I can stick with the intake I have and just change the cam or whatever at this point I'm happy. but before I die I'm gonna put A blower on the old gal. my boy's ask me the other day witch one of us gets the scamp when I die.told them nobody put me in my car and bury us both. they told me that would take two grave plots and we wouldn't have enough money for a grave stone. well I got it all planed out now 1 grave plot deep put me in the drivers seat throw me and the car face down in the ground and fill us with dirt leaving nothing but the bumper above ground. write on the bumper my name and anything you think fit. but most important thing to do is take my old cd's find the the one that play's the song I'm on a highway to hell put it in my radio turn it on and make sure my foot is on the gas peddle
got everything you said on the car all ready but cam and manifold thanks I'll check it outThere is a guy racing a stick shift scamp in Cincinnati. It’s a stock stroke 340 that is thirty over. He has some serious time put into the heads and runs a custom bullet cam but the car runs 11s and I believe even 10s all day long. He runs a victor single plane intake and it works.
If I was in your shoes Fred I would put on headers, air gap intake and search around here for a nice off the self cam that others are using with good results. That combination with a 750 cfm carb will make close to 400 hp.
thanks for the info. nice to talk to someone who caresJust shy of 400hp here; The Little 340 that could
Go to the next cam size up!
Never a problem! Like most here, we are into helping. Though you do lack a good bit of info about your car, as someone mentioned, that is not (yet) part of the equation.thanks for the info. nice to talk to someone who cares
You're smuggling shotgun shells in Your derriere?!?!I have 410' s in my rear end [? that didn't sound good] and a gear vendor over drive I'm hoping that would help with the tunnel ram. but don't leave me hanging how do you know
I think I'll stick with changing the cam. don't need to much power I have a lead foot. and your right about not knowing much on building my engine I haven't had a muscle car since 1979.Never a problem! Like most here, we are into helping. Though you do lack a good bit of info about your car, as someone mentioned, that is not (yet) part of the equation.
I also don’t like to just spend your money. I’d rather assume that your close to a actual no money/restricted money build. I’m not anti dual quad/tunnel ram but would rather sensibly spend your money.
And of course, I sometimes answer with sarcasm. Like;
.750 roller cam with 1.6 rockers for more lift with CNC W9 heads on a 476 cube small block will get ya 400 hp!
LMAO!!!!
Did You know that you can rewire that GVOD and use it as a splitter. Then you can go just as quick on less hp.
Here's an A998
2.74-2.13-1.54-1.20-1.00-.78od,GV in red;and splits of .78-.72-.78-.83-.78into od
With those splits you can run a tighter LSA too, like maybe 106
But you'll need some heads to do the work with a lil less cam. And you'll probably need 4.30s to trap well in direct.You'll be sitting close to or at peak-power from about35 mph,and on thru the traps, like a snomobile.Get a rev limiter,for sure.And you won't need near as much TC, and that makes the whole pkg street/hi-way friendly.
With aluminum heads you can bump the Dcr up to about 8.8 or even 9.0 (Some guys here are a tic over 9.2 on pumpgas). if you don't mind running premium,(while you put the tune in), and that will make so much grunt with that starter gear you won't be able to stop smirking. You're gonna have to spend a serious wad of cash just to make it stick off the line.
I mean imagine you stall it at 200ftlbs, and you multiply that by 4.30 and by 2.74 and run 28" tires. That will get you 2019 ftlbs to the pavement, corrected to a 12" radius. That will spin any street tire. And 200 ftlbs is easy with aluminum heads 11/1Scr and a 230/237/106 cam and about a 2400TC. You'll be spinning those 28s to 80 mph.
1) Here's a combo; fast-rate 276/106 in at an ICA of 60 *
Static compression ratio of 11:1.
Effective stroke is 2.66 inches.
Your dynamic compression ratio is 9.02:1 .
Your dynamic cranking pressure is 186.68 PSI.
V/P (Volume to Pressure Index) is 155.......................................................155
Shoot, I'd try the factory A998TC; on account of you only need 150ftlbs at the crank with that starter gear(4.30x2.74=11.78).
2) Shoot you could run the next smaller cam, a lil less compression, and a tunnel-ram,lol.Here it is with an ICA of 57*
Static compression ratio of 10.75:1.
Effective stroke is 2.72 inches.
Your dynamic compression ratio is 9.00:1 .
Your dynamic cranking pressure is 186.15 PSI.
V/P (Volume to Pressure Index) is 158................................................................158
Are you kidding! Now you're making 360 torque.And I know what that feels like.
3) I ran this in my 367 for 4 years 270/110 cam; ICA of 61*
Static compression ratio of 10.9:1.
Effective stroke is 2.86 inches.
Your dynamic compression ratio is 8.91:1 .
Your dynamic cranking pressure is 183.76 PSI.
V/P (Volume to Pressure Index) is 164................................................................164
This thing spun 295s everywhere all the time; even 325DRs. And it ran on 87E10.
FWIW
My 3467# 68 Barracuda went 93(1/8th) with a stick and splitter with an Eddie headed 367, and a 230 cam. That computes to 433hp. My engine could only hope to be making that. I think it might be making 380ish,400 tops. A fast-rate 230 is a nice street cam.It runs 87E10.
If you want a tunnel ram, get one, but it's not needed to do what you want. Dual quads are an old school look and an attention getter. They do perform as well as look old school tough. They are more difficult to tune properly, and they will wet the oil down with gas more if you do a bunch of short trips to the store and back.
In the end, it's up to you.
