Turbo Action Converter ID
70wayfarer
new zealand
hi all,
i have a turbo action 8"converter i bought a few years back, but can't find the spec sheet that came with it.:banghead:
it has these numbers stamped on it. on the back 17918 36 97015. on the front 76 z313 45zst. has 20g weight on it.
is there anyone out there that could decode this for me please.
cheers
hi all,
cheers
17918-36 is the model/part number ..fits 727...
97015 ...converter build in 1997...serial number 015
the -36 number refers to the stall on the converter...and the rest of the numbers are Greek and you will need to call TA
http://www.turboaction.com/frame.html on left side of page click on torque converters
then click on Stall Speed Applications 8" in center of page....you will see some 17918 models...but nothing with the -36 after it.....could it be -38?
look on the 8" steel stator page, there is a -36 listed. It's likely a pretty high stall because I think as the T/A dash numbers go down, stall goes up.
as the number get bigger..the stall get bigger with a TA...
Yes, you're right on that. I thought I saw something that was different. Might have had the first five digits different.
thanks for the info guys.
found it under 8"pro series steel stator. 727. '67-'92. 17918-36.
probably mid to high 5000 stall range.
cheers
cheers
going to depend on the engine in front of it....that is why they are called Torque Converters...
