Palmetto
I have come across some slants and want to determine if they even turn over or are locked up. V8s have the large nut on the front of the crank that you just put a socket on and turn, what about a slant???
If the fan & fan belt is still on, you can push down hard on the belt and use the fan to turn the crank.
slant sixes are tapped in the end of the crank, 3/4 unf bolt, thread in a bolt and go :burnout:
Mike
