Make one of these out of some aluminum welding rod and a 2 x 4. Works great for the new HD TV signals.
Daytona 500 on Sunday, works for that.
RRR, This is made and sold by a local boy!!!
That same guy in the video I posted tests just about every outside antenae made. You can check out his other videos to see how the other types/brands perform. He's brutally honest and doesn't hesitate to tell you that an antenae is crap or OK or excellent. I posted the video so can judge for yourself before you buy something that's not going to help you and so you don't waist your money.Made outta fence. Alrighty. What is that thing he keeps talkin about that's soldered on that "might come off"? I don't have one of those on my antenna "that I know of" unless it might be "built in".
I posted the video for RRR, he was looking for help and prefers NOT to spend an arm and a leg (or an eye, he's running out of eyes...LOL). The guy even goes to the trouble of explaining how well and antenae works with respect to having to get a signal over 1 or 2 ridges (hills) and distances. Most folks aren't savy on how antenaes work when it comes to specs/designs/analysis....eh!!!You just HAD to resurrect this, eh?
These DIY antennas----these only work well IF, and I say, IF, I say.........
1.....Whatever design you build provides enough gain for whatever signals are available
2......You are able to mount it high enough if need be
3.......The dern thang is actually built "in tolerance" and BOY IS THAT AN UNDERSTATEMENT
You are talking about UHF signals and UHF antenna design, and I KNOW you are all electrical engineers specializing in UHF antenna theory, design and analysis. I know I am............NOT
But I have built a few antennas, and without decent test equipment, you are not going to optimize some jackass design you found on YouTube.
Not only that but ANY antenna must be properly decoupled from the antenna. In short, and using coax, this amounts to a balun---BALanced-UNbalanced coupling transformer. Otherwise the COAX SHIELD becomes "part of" the antenna system, and your hard wanted gain and directivity just went right out the window
There are rooms full of books written on this stuff. Rooms full.
Success, it's simple and it works.
Don't have to over think it.
None of this is true.
"I was lucky" would be more accurate
Answer me this? Do you have the same "simple success" when you build an engine? Ever run into something like, maybe, when the bearings just don't fit, because someone sent undersize, or you mis-measured the crank?
My nephew streams everything that he watches on TV from his phone. No antenae required..........eh!!!
My son uses his phone to cast whatever he wants to see on TV from his phone......no antenae required eh!
No Mobile hot spot required ....eh!! Most phones are 4G now so if an FABO member uses their phone for posting here....well then they have a signal from where they can stream from their phone to their TV. Even if you have no internet in your house you would be able to get a phone signal unless you're way, way out in the boonies eh!! If you were that far out in the bonnies you wouldn't be able get an antenae signal anyway, unless you lived way up on mountain top (high altitude)......eh!Just guessing but he probably has the Mobile Hotspot on his phone to use as an internet connection. Then goes wireless connect from TV to Phone, once you access online you can do most anything. Using Cell Tower Network To bring in the data.
No TV antenna required.
Would be interested to hear more about how they do it.
Used my cell as a "hotspot" while watching TV a few years back in Sask. While I was waiting for ssatelliteto get hooked up. Cost me $15 to watch a 1 hour show. That was the end of " hotspotting"
Hotspots are good for a quick temporary backup to check an email or a little bank business as they are secure.
But yeah definitely don't don't want to sit and play YouTube videos for hours, data all gone ????
