UCA adjustment
Snake
Mopar Nut
Belleville Canada
I did not take note of were the cam adjusters were on my arms when i tore it apart.so now how can I get it close untill I go to the alinement shop.Should I do this adjustment when the spindell is off,havent got that far yet.upper arm is inplace.thanksss for the help.And if you havent heard FABO is #1:cheers:
Where they were before wouldn't help much anyway. Best to just center the concertics and head for the front end machine.
Center the adjusters like Redfish said, then...If you have a carpenters level....lay it vertically against the rim and adjust to get bubble level.
That will at least get camber in the ballpark of zero degrees for the trip over.
You will have to check it with weight on, and roll the car back and forth a bit to let suspension to settle before using the level.
Good luck.
