JGC403
I want to make a list of everything that needs to be done under the dash and to the interior wiring and engine wiring before the dash goes back in on my 1968 Barracuda. All the electrical upgrades I want to wrap it together in one harness to make it look as stock as possible.
What I have so far on the list is:
1. Windshield Wiper Seal kit, original ones probably leak by now
2. Rebuild wiper arm linkage, originals are probably worn out
3. Space the Heater Blower motor for Big Block valve cover clearance
4. RTE gauge cluster 5 volt limiter
5. Amp meter bypass, convert amp gauge to voltmeter
6. Convert to post 1970 voltage regulator
7. Headlight Relay upgrade
8. electronic ignition upgrade
Are there any other must do's that need to be done that would be difficult to do with the dash in?
