...Undercoating...:(
omahamoparguy
Man this scraping under coating really sucks! andbody got any tip to make it go easier. I'm using a heat gun and putty knife. And it is thick in spots.
Trivia; the building that the original Hooter's restuarant started in was previously a place that did undercoating on cars. (clearwater fl)
(...whats in that chicken wing sauce??...)
I have great luck using a MAPP torch. Usually $8 a bottle at Lowes/HD. Doing the frame and wheel wells. It losens well and peels off with blade nicely. Still in progress.
I saw them do this on Search and Restore from Powerblock
spray a healthy does of PB Blaster on it and let it sit over night.
I hear this stuff works real good on animated rabbits, not sure about cars! If you're pullin off the under-coating on a serious note I'd get it dipped, although I think they need to drill holes into the wheel wells so it will submerge properly.... I'm just.... a perfectionist.... if youre gonna do something... go all the way!
As stated before, a torch. Get it hot and scrape off with a putty knife, then lacquer thinner on a rag takes the rest off.
Did undercoating in Cda. many years ago.Varsol was the best liquid we found for removing undercoating.That and a little patience and elbow grease.Just bought a set of inner fr. fender inner shields for my Cuda.Undercoating was unusually thick.Used a hammer and small chisel to remove the really heavy coating to get to the bolts.A good undercoating job is usually only a few mils thick.Hope this helps.
