73stroked duster
73 duster drum in rear disk up front manual brakes. any thoughts on common upgrades to improve braking. Car does stop ok with heavy foot pedal. Not sure how safe in a panic stop though.
Looks like I am only pulling 12 vacuum so I think a power booster is outMy thoughts, add a power booster and MC, and, or upsize to the larger brakes from a 76-78 car.
I run a booster with 13 inches of mercury.Looks like I am only pulling 12 vacuum so I think a power booster is out
I think my best option is to upgrade to the 11.75 rotors and new calipers. Can you recommend a complete kit?No power booster needed, they don’t improve braking force just the pedal effort. You can accomplish the same thing by changing the size of the master cylinder bore. A 15/16” bore master will raise the line pressure, but also make the pedal a bit lighter. You do get a little more pedal travel, but it’s not excessive and it actually allows for better pedal modulation.
DoctorDiff sells a great 15/16” aluminum master and adaptor. I run them on my Duster and my Challenger.
For more braking force, if you have A body 73-75 calipers they have a 2.6” piston. The 1976 A bodies, as well as pretty much all the other body styles, used calipers with a 2.75” piston. So you can switch to later slider calipers and get a larger piston, bolts right on, more braking force.
If you run 15” wheels you can also go to the 11.75” rotors and caliper brackets, they bolt right on to the 73+ spindles and use the same calipers. Just upsizing the rotors adds another 8% of braking fires if I remember my old calculations correctly.
Was just looking at their site. For 73 the kit list front mount caliper location and my car has the calipers facing rear. Does this mattterDr Diff.
I think I have 1.031 bore. Just installed a few months agoWhy not measure your MC diameter first?
Maybe it's just a case of installing a smaller MC.
Would the 11.75 rotors and 2.75 calipers be a better fit with the 1.031That's probably the problem right there.
I've had 1-1/32" MC with power brakes on my setup. I also have 2.75" calipers and 11.75" rotors and braking was just so-so.
After I installed a 15/16" MC braking has become much better and like it should be.
Ok so the only time he booster does not, or may not, work 100% is when the vacuum drops below it's minimum threshold required vacuum to achieve maximum assist. So when does this occur during braking? It doesn't,unless you have a monster cam and a loose convertor.Looks like I am only pulling 12 vacuum so I think a power booster is out
