Upper contorls fit on '65
matarcher
65dartonly
Modesto, CA
does any one know if an upper control arm from a 84 "m" body (new yorker) fit on a '65 dart? this is for a large bolt pattern disk brakes set up. some one mentioned this to me but i wanted to get a little more input before i bought them. any help PLEASE!
The spindles will work but I believe you need the control arms from a 73-76 A-Body with the large ball joint.
Hey Matt,
Concerning the "M" body stuff that I have, I can bring it out when
I come to Fountain Hills. Take the stuff and see if it works for you.
Don't forget, I do not have the upper control arms or
dust shields.
If it does work out, then we'll talk about $$. (cheap)
If they don't work...you can put them in your stock
instead of mine.
And no you don't have to hurry up and try them. Just whenever
you get your car going.
