Upper Control Arm bolt
nodemon
St.Louis
I have an upper control arm bolt that refuses to come out. I have soaked with PB Blaster for several days, put heat to it and beat it with a 2lb sledge...WON'T BUDGE..!!
Don't think I have enough room to cut it out...maybe with the right tool...but limited space..
Frozen ? Will not turn ? Picture.
I'm guessing rust welded..?
So you got the nut off but the rest of the bolt wont come out of the bushing sleeve ?
Disconnect upper ball joint from spindle so you have full range of motion on the upper control arm. This will give you more room to work.
May be time for a torch to burn the bushing out and loosen the rust
Remove brake line and put clay or some type of heat barrier behind the eccentric bolts to prevent paint burn.
Yep.. The other side, the bolt snapped off, but I was able to work the bolt out.
Ya, in this case "HEAT" is going to be your friend. Any of your car buddies have a portable oxy-acetylene torch set, that they can bring over?
Or how about a grinder with a cut off wheel.
Something like what i use around here, when things get stubborn.
It's disconnected from spindle.
I don't have a "real" torch, just a propane one. I've held the flame to it for long periods of time and beat on it while applying heat. I guess I'll just keep going at it that way. I've had some stubborn rust welded nuts and bolts in the past, but this is ridiculous. I might try getting my angle grinder in there with a cutting wheel..If nothing else, maybe cut in enough in a few places to weaken it.
Does the bolt turn within the bushing? If so, I would put an air ratchet on the bolt and simultaneously take your 2lb sledge and bang away. If you need a second person, I'm in the area.
I've got narrowed down to the inner sleeve.. The bushing will turn independently, but the inner sleeve won't.
in a similar situation i welded a piece of angle iron to the head of the bolt so i was able to get some swing on it and drive it out from that side.
I wouldn't pound it......You may bend the mounting tabs on the frame.
IIRC, I used a sawsall on both sides of the bushing between the mounting tabs and the bushing and removed the control arm once both sides were cut. Worked the pieces out once the control arm was out.
Can you get a shallow 1/2" drive impact socket on the bolt head & work it back & forth a bit at a time with a breaker bar to free it up?
The bolt spins freely... It's "stuck" to the inner part of the bushing not allowing it to back out. I've cut one side of the bushing and bolt,but not enough room to cut the other side.. I hate to do it, but I may just have to cut the control arm.
YIKES! Well, someone here probably has a control arm & bolt assemblies for you, if you have to go that route. The car doesn't look rusty. I guess water worked its way in there. Could have been a worse, way more costly problem too, just remember that before you start cursin'. :lol:
Tried to get a set of control arms from the junkyard a few years ago. Bolt appeared rusted to the inner sleave of the the control arm bushing. I'm thinking that one of those oscilating saws are thin enough and controlable to cut through the bolt ans bushing with out causing too much damage around the frame rail mounts.
I thought about a Sawzall, but thinking not enough room, at least with the one I have.
Luckily, I purchased a pair of arms some time ago and had the bushings and ball joint installed.. Same with lower. I figured that way it would be an easy in and out job with no down time getting joints and bushings installed.. As usual, my "easy" quick job turned into a PITA...lol
That's exactly what I ended up using, my Milwaukee oscillating...took 3 carbide blades but did the job. This front suspension stuff SUCKS..lol
It's heavy, time consuming work, for sure. Makes me wish I had gotten into another end of it, as suspension and alignment work has made me at least 10 years older than I really am, maybe more.
